Idea for oil cooler
Idea for oil cooler
While fooling around under the truck, and removing the engine. I had an idea with the engine oil cooler where the oil filter screws on. 2 heater hoses run to it from the lower radiator hose. 180 deg water pulling heat away from engine oil. Idea is route the intercooler lines to circulate through the oil cooler with water that is same temp as outside air. It will be adding more heat to the intercooler system but with a larger aftermarket exchanger I don't think will add enough to cause any detonation or pinging problems ,benifits are cooler oil is better! especially in AZ. All you would need to buy is a lower hose for an f150 without an engine oil cooler, new black heater hose longer to tie it in.
Engine temp. is taken from the coolant temp., not oil temp.Since i have the stock exchanger laying around ,i was now thinking of mounting it behind the JDM aftermarket one and getting another intercooler pump and it would now have its own sealed circulation system.
