headlights not working (97 f150)
I searched only to find the same problem but no solution.
headlights just quit working when the switch is turned on.
I can pull back on the turn signal switch and the high beams will come on till I let it go.
Fuse #8 under the hood is good.
All other lights inside and outside work as they should.
Which switch?
I know now this is an old thread; however, which switch did you take apart the turn signal arm? I have the same issue and would like to fix it myself.
