Brake Warning Light
Old 02-20-2016, 03:54 PM
kpg7121's Avatar
Brake Warning Light
My F-150 is an 07 with 120,000 miles on it. I have an issue with the dash brake light coming on. The light will come on & then go off. I can drive the truck for 25-30 miles & the light will not come on. Then I can drive a couple miles & the light will come on. I recently had a state inspection done & according to the shop the brakes are fine. The shop wants an hr. to diagnose the issue. Anyone have an idea why this light will come on & off for no apparent reason? It's annoying & I want to trade the truck in so I'd like to clear this up.
Thanx!
Old 02-20-2016, 06:55 PM
projectSHO89's Avatar
Have you checked the brake fluid level lately?
Old 02-20-2016, 07:54 PM
glc is online now
Also, pull the parking brake release and stick your foot behind the pedal and lift it. It may be part way engaged.
Old 02-21-2016, 06:51 AM
kpg7121's Avatar
Brake fluid is fine & parking brake is not engaged. I even set it & released it a couple times just to be sure.
Old 02-21-2016, 07:22 AM
It's also possible that the cluster is failing. There's a number of things that can cause the symptom.
Someone who knows what they're doing will need to get their hands and eyes on it and actually diagnose it.
If you're trading it in, why bother? It becomes the dealer's problem after that.
Old 02-24-2016, 07:58 PM
Matthew Winter's Avatar
Thanx!
It's the cluster known problem with these trucks cheaper to get it rebuilt
Quick Reply: Brake Warning Light
