Brake switch gets no voltage. cant shift out of park and no brake lights
Okie so I have a 1999 ford f 150 here and the trans wont shift out of park with the engine running. once I turn the truck of it shifts fine, brake lights don't work either. now the brake switch is replaced and the solenoid as well however the connector to the brake switch is not getting any voltage at all. im having trouble finding the circuit diagram to trace where the circuit goes after the brake switch connector. if anyone can give me some insite on this I would greatly appreciate it.
on
Go directly to fuse F13 under the dash and check it FIRST.
If blown, do NOT [note the added emphasis?] just replace it as it's all too likely that you have a truck that recall 05S28 was not performed on and the truck is a fire hazard. Either call your dealer and check or use Ford's online recall checker to see if that VIN had the work done. If it has not, disconnect the switch from the master cylinder before replacing the fuse.
If F13 is okay, check the wiring immediately adjacent to the brake pedal switch. It has a bad habit of breaking the conductor inside the wire insulation and you can't see it.
If you have to drive it in the meantime, follow the shift interlock instructions that are in your owner's manual.
on
Check where I told you to, it's a not uncommon failure.
The brake lamp circuit on a 99 is very simple. The feed from fuse F13 goes to the switch via light green.red wire. When the switch closes, that voltage is distributed out to the stop lamps (high mount directly, corners and trailer adapter via the MFS) on the light green wire.
