Where is negative ground connection to engine
Old 11-27-2015, 02:20 PM
cyaificya's Avatar
Have a 03 f150. Trouble starting. Battery good, solenoid . Dash lights come on when turned key but go to start and everything goes off but battery light and no sounds of trying to start
Old 11-27-2015, 05:40 PM
JackandJanet's Avatar
Cya, I moved your question to the Electrical Section. You should get better responses here than in the "Hello" forum.
- Jack
Old 11-27-2015, 07:52 PM
Roadie's Avatar
I assume you have cleaned the battery connections. If one has been replaced and the cables are clamped, clean up that connection too. I just had the same problem and it was the clamp on the negative connector. I sprayed the cables with contact cleaner and re-clamped.
Old 11-27-2015, 09:26 PM
SSCULLY's Avatar
Did you check the solenoid or starter motor relay and how did you check it ?
Quick Reply: Where is negative ground connection to engine
