Looking for help diagnosing a power window problem
Old 04-07-2011, 10:31 PM
Norandy's Avatar
Actually, the closet place was oreilly's and all they had was a reman... I didn't check the pigtail after I replaced, but since I am going to have to dig into it tomorrow again and probably return the motor , I will check the pigtail.
Old 04-07-2011, 10:33 PM
SSCULLY's Avatar
If you are digging into the door again, prior to removing the motor, pull the pigtail connector, and hook a meter or test light to it, then try the switches again.
the meter will read _ and then reverse polarity when operating the window, that will tell you if you need to pull the motor, or look somewhere else.
Old 04-07-2011, 10:40 PM
Norandy's Avatar
The closest place was oreilly's and all they had was a reman motor. I will check the pigtail again in the morning and probably return the motor.
Old 04-08-2011, 06:02 PM
Norandy's Avatar
I checked the pigtail and got 1/-1 on both switches. I took the POS motor back and got a new one, spent about 30 minutes (took me a few minutes to find what the kids did with my sockets) and everything seems to be good.
Quick Reply: Looking for help diagnosing a power window problem
