Warning Buzzer 5 times 5 times HELP!!!
I have a 2004 F150 screw. Just recently my truck's wanring buzzer has been going off about 1 min after I start the truck. ther are no wanring lights in the dash cluster, just a buzzer that buzzes 5 times and repeats 5 times.
Can anyone help?
Can anyone help?
on
Search this forum for the term beep there are 72 threads.
If you read through them, this is a case of Your airbag warning light in the dash is burned out AND there is a fault in the airbag system.
https://www.f150online.com/forums/el...tone-code.html
Quick check, turn your turn your ign to the run ( do not start ) position, and the bulbs should illuminate. You should not see the airbag light on the cluster.
The air bag light in cluster comes on than goes out same as the passenger on/off air bag light. but I did have a code of the impact sencer in front of the rad. I checked it and found a crack on it and just waiting for dealer to get me one. Do you think this might be all in one same problem?
