Speedometer not working 2003 F150 XLT
Old 09-05-2007, 07:14 PM
TRITON_2002's Avatar
Originally Posted by projectSHO89
Auto parts stores don't have readers capable of pulling these codes. Save your trip.
Don't replace that oil pressure switch based on that code, it's probably bogus.
Steve
Is this not an OBD code? Thas why I suggested he go get a diagnostics code, not the cluster info, this code is probalby bad.
Old 09-19-2007, 03:56 PM
fastskier's Avatar
dealer thinks its the instrument cluster - they've ordered a new one for $500.??
Old 02-26-2008, 05:23 PM
rm125's Avatar
fastskier,
I have the same problem, did the instrument cluster fix the problem?
Old 08-30-2008, 08:51 PM
rm125's Avatar
The instrument cluster did fix my problem. Also the new cluster had to be programed by Ford.
Paul
Old 08-06-2014, 01:38 PM
Trucknut97's Avatar
Speedometer
It is not the whole instrument cluster itself it is the soldering point in the back where your speedometer is connected they are cracked thus for causing an interrupted circuit ! Pull the cluster out and use a magnifying glass to look for a circular crack on the solder point then clean it up and resolder !
Quick Reply: Speedometer not working 2003 F150 XLT
