F1 error code? edge evo
This is from our Gryphon manual, but Bill says it should work the same:
ERROR CODE 0xF1 (IN CUSTOM MENU) – If you are receiving this error code while trying to configure
your custom options, disconnect from the OBDII connector, turn the key to the ON position, and plug the
Gryphon™ back in. After getting to the main screen (past Intro and Disclaimer), wait 15 seconds. This will
give your unit time to load parameters it needs to perform the custom changes. You should now be able to
perform your custom changes.
Hope it helps!
Hope it helps!
