F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Special Interest > Articles & How-To's
Thread Tools Display Modes
  #31
Old 04-14-2009, 11:51 PM
Vehicle: 1998 Ford F-150
Send a message via AIM to Raptor05121 Send a message via MSN to Raptor05121 Send a message via Yahoo to Raptor05121
Quote:
Originally Posted by MudTerrain View Post
I've got a question, what type of LEDs, directional or ones with LEDs on each side?
Well the actual bulbs in the green arrows you see are 37's if that is what you are asking.
Quote:
Originally Posted by cH1rO420 View Post
Yep, I wanted to know if you changed them out too. If so what bulb number, THANKS! Also Nice job on the upgrade, your truck sticks out more and more.
No, I saw no need to change those out. I still like the directional arrows to be green...just incase you leave them on going down the road the green will stand out against the blue to prevent humiliation
Quote:
Originally Posted by Zaairman View Post
On my 1999 Ext cab, it had the airbag switch, but it had a connector on the back of it, so no unscrewing was needed. Its the same setup on my 2000 F-250.
Thanks, I'll add that in too!
Quote:
Originally Posted by Blue150 View Post
So, theoretically, one could obtain blue 194 incandescent bulbs, install them and not have the typical LED hot spots but would still have a nice blue tint. Would you agree? I only ask because I powder coat these 194’s to the color I desire (transparent) and they never fade or burn to a different color. If this will work (in theory), I would like to try it on my 08.
In theory, yes; actuality- no. My friend right down the street did this and although it didn't have "hotspots" the color was no where near as blue as mine. He did not replace the 37's up top like I did and you could only marginally see the difference between the blue-coated bulbs and the stock bulbs. You could try doing a DEEP blue, but I think that would restrict the lumenous output of the lights themselves
-Alex
  #32
Old 04-15-2009, 10:09 AM
Vehicle: 2008 Ford F150
Cool, thanks. I might have to see if I can find some LED's that disperse light better though. I want to do this but I don't want the hot spots.
  #33
Old 04-15-2009, 11:40 AM
Wide-angle LEDs would solve this problem but there are plastic runners inside the cluster that help disperse the light that are the shap of the bulb. My 194 LEDs are smaller than the incandescents, so they fit fine, but any other type of light that is bigger than the standard bulb wont fit correctly.
  #34
Old 04-15-2009, 12:00 PM
Quote:
My thought is to scuff the surface of the LED from a polished clear to a satin surface. To disperse the light better and make it softer. I hope that makes sense.
  #35
Old 04-15-2009, 12:06 PM
It does, but with the actual production costs of LEDs at mere pennies, I have personally had the plastic lense popping off and all sorts of problems with just a tiny bit of pressure. There is a delicacy when handling those things, as the prongs bend off real easily as well... Not to mention scuffing the surface won't yield visible results, IMO.
  #36
Old 04-15-2009, 07:09 PM
Vehicle: two 2003 F-150s
Send a message via AIM to Patman03SprCrw
I would think that you could scuff the tip of the bulb if you are having hotspot issues, and make less output out the tip, and seem like more light from the sides.
What was the verdict on the dimmer? Still functioning or not?
  #37
Old 04-16-2009, 12:14 PM
Well try it out and let me know.
And yes the dimmer works 100%. I use it all the time!
4.2L V6 - M5OD | 16" Dual Efans | 2" Drop Shackles | K&N Series-77 | Port & Polish TB
Bent Frame Mod | Custom Down-Turned Bumper | Accordian-style bed flooring
  #38
Old 04-16-2009, 11:34 PM
Vehicle: 1998 Ford F 150
Hey nice write up I did this mod a while back but chose some green LED's got them from www.superbrightleds.com I used # 194 and # 37/#74 Led's
_____________________
  #39
Old 04-16-2009, 11:40 PM
looks nice!
BEFORE EVERYONE STARTS ASKING, THAT IS A KM/H READOUT
once everyone sees "160" I know they're going to ask: "where'd you get a 160-speedo?!?!?"
  #40
Old 04-16-2009, 11:44 PM
looks nice!
Didnt you know that was on the '98 50th aniversry Lariat's in Canada.....LOL
  #41
Old 04-17-2009, 12:50 AM
mines a 50th anniversary edition too. but i know some people on here in Canuckland that did the swap and the yanks down here think its a 160-mph speedo
  #42
Old 04-17-2009, 09:49 AM
Vehicle: 13 FULLsize ole' Ford rigs
Send a message via AIM to adrianspeeder Send a message via MSN to adrianspeeder Send a message via Yahoo to adrianspeeder
Interesting, my '97 has blue gauge/steering wheel lights stock, but green door switches. Grandfathers '97 is green all around.
Adrianspeeder
  #43
Old 04-18-2009, 12:44 AM
Vehicle: 2002 Ford F150
Send a message via AIM to f150fella08
nice write up man, id love to do this but i think its a little to much for me, id love for mine to be bright blue
True Dual Straights, No Mufflers, H Pipe, Maggie Hi Flows (94106) http://www.youtube.com/watch?v=vt6qpxghCwQ
  #44
Old 04-18-2009, 02:03 PM
Vehicle: 2000 Ford F-150
How much do the LEDs cost? Total cost of the project???
2000 F-150 Lariat 5.4L, Gryphon Tuned by PHP, S&B CAI, Magnaflow Magnapack, DynaPro M/T's, RCD 5" Lift & 2" ProComp AAL
  #45
Old 04-18-2009, 04:33 PM
A pair of 197-LEDs costs around $2.00-$5.00 on eBay. So you're looking at a 2 hour-$15 project here!
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company
