Newbee questions on lowering
Old 04-23-2016, 11:29 PM
oldguy668's Avatar
I'm picking up a 2016 regular cab/short bed 4x4 next week. I want to drop the rear 3" and the front 1" or2". I'm noticing 1-2" drop rear spring shackles and I'm wondering if they can be used in conjunction with removal of the 1" axle spacer to achieve 3" in the back.
Old 04-25-2016, 01:04 PM
onlya377's Avatar
I have the same thing on order and wonder the same thing!
Old 04-25-2016, 01:31 PM
Yes.
I did a 2012 Platinum with 2wd struts, remove block and shackle install
https://www.f150online.com/forums/st...ml#post4902176
Old 04-25-2016, 01:57 PM
onlya377's Avatar
Thanks, didn't know if they'd be the same as the older ones, I know that Crown, DJM, etc... have a different lowering kit for the 15/16's.
Old 04-25-2016, 02:19 PM
I believe the shocks (comparing 09-14 to 15/16) are different, but as long as you stayed with 15/16 factory parts you should be fine too
Old 04-25-2016, 04:15 PM
oldguy668's Avatar
So if I do the block delete and shackles, I should be able to go 2" or 3"? Then shorter springs in front to get 2" ?
Old 04-25-2016, 04:49 PM
I'd go factory 2wd struts up front. Keep your factory springs
Rear 2wd shocks are optional depending on how much drop you do
Block delete (order 2wd u bolts) qty 4 u bolts
2" sackle install.
Should net you 2/3 or just shy
Old 04-25-2016, 08:41 PM
oldguy668's Avatar
Thanks, Patman. Exactly what I needed.
Old 04-26-2016, 08:26 AM
Phillip123's Avatar
Now get down to business
Quick Reply: Newbee questions on lowering
