2" BORA Wheel Adapters Installed
Finally installed the 2" BORA Wheel Adapters. I have to say these things are high quality! They are hubcentric and wheel centric. One thing I will be letting Lenny know is that the studs are too long. I need to trim them so I can put the center caps on. Other than that they supplied the additional lug nuts needed to adapt them. I put red Loctite on the factory studs also.
My set up is as follows
-2.5" HBS Level
-Factory 20's
-295/60R20 Nitto Trail Grapplers
This gave the truck the perfect stance to me. I will get better pictures in the daylight tomorrow as when I finished it was getting dark.
Tip for doing the fronts
Rubbing
Trimming
Rear Before
Rear After
Front Before
Front After
I don't need to be lectured on how these are unsafe yada yada yada. Properly installed and maintained, they are no more dangerous than a non maintained wheel. And it is no different than a wheel with the same offset.
I love the new look the truck has.
-Curtis-
-2.5" HBS Level
-Factory 20's
Rubbing
Trimming
Rear Before
Rear After
Front Before
Front After
-Curtis-
I wouldn't say never, but it will be difficult. Heat is what breaks down Red Loctite. The heat from the brakes alone will gradually break down the Loctite. Not too concerned as they are here to stay.
-Curtis-
30" LED From www.trailworthyfab.com. I'm pretty sure they are Auroa light bars.
OEM Tow Mirrors for 04-12
-Curtis-
-Curtis-
-Curtis-
-Curtis-
-Curtis-
-Curtis-
