NCSU's HID Retrofit Headlights...
#91
New pics....
Adjusted HIDs, might aim them a little higher:
Ground level:
~4'-5' off the ground:
Further back:
Light output:
Misc:
Driving vid low beams only:
http://www.youtube.com/watch?v=GPZlxWKwM2o
- NCSU
Ground level:
Further back:
Light output:
Misc:
- NCSU
#93
#94
Hey, one more suggestion NCSU. If you cut the center wire going to the turn signal bulbs and use that to power your CCFLs, then your CCFLs will turn on as if they were your parking lights and the yellow bulb will not, but the turning signal bulbs will still flash yellow when engaged. It looks great when you only have the parking lights on or when you are riding with just parking lights and fogs.
#95
I'm thinking I'll wire the devil eyes into the parking lights, and also tie them into the turn signals so they'll light when the turn signal is activated. They would stay constantly lit with while the parking lights are on though.
Then I'll put the CCFLs on a separate switch, powered, so I can flip them on at will, regardless of any other lights being on or off.
- NCSU
- NCSU
#96
Hmmm... not sure I understand, but just in case, I wouldn't wire the CCFLS to blink when the turn signal is activated. I don't think that would be good for the CCFLs. I'm sure Brian can shed some light on that for us. Anyway, I'll try to put up a video in a bit so you can see how mine look (Brian has been asking for pics forever, so I need to do this, anyway). We might be able to share ideas from there.
We may be using different terminology. To clarify, CCFL and Halos/DevilEyes/Whatever are the same thing in my book.
#97
The devil lights he is talking about is the actual projector "lighting" up from the inside. I thought that was just an LED inside the projector the lit up the inside with w/e color you put in there. Could be wrong, though.
The CCFL are the rings (like the Halos/Angle Eyes/Devil Eyes some people do.) Those Devil eyes are just a red CCFL ring, as opposed to the Angle Eyes, which are a light blueish CCFL ring.
#98
#99
- NCSU
#101
As far as lighting concerned, on a scale from 1 to 10 with the projects being a 10, how would you rate the aftermarket halogens? What are you going to do with your heads or have you already put them up for sale? I suppose acquiring replacement heads would be the first step. I was going to ask about adjustment, but that seems to have all worked out based on your pics. Is there anything about the setup that you don't like or that has been problematic?
Looks good. I'd like to do something like this, but it's not that high on the want list. Come hunting season, they will move up on the list, but I'm wondering how much lead time one would need to have from the time the order is placed to install? Did Sick supply everything except the heads?
Appreciate the help.
#103
ETA: Looks great NCSU! My wife and my wallet hate this thread.
#104
You can send Brian a set of headlights to work on, or he can provide a set at an additional cost.
Other than that, it's all pretty straightforward and I haven't had any issues.
Yup!
No problem!
- NCSU
#105
Wired up the parking light CCFLs, pics once it gets dark.
I also swapped the OEM parking lights for amber LED ones.
Here's the parking light LEDs, looks like I did go with the 4 LED setup, not the 2 LED one I linked to previously.
And here's what the headlight looked like prior to LED installation:
and after:
and after:
