Tuner
And NO, the PCM cannot correct for this - specific tuning correction is the ONLY way. Don't let the asshats tell ya different
Do yerself a big favour - and be proactive (unlike a lot of folks who go ahead & add intakes and other stuff without thinking) - CALL one of the respected custom tuners and ASK them - first.
http://www.vmptuning.com/store/index.php?
"We can tune for different cold air intakes on 05+ Mustangs and 04+ F150s. Any aftermarket intake that flows well and puts the slot-style MAF sensor into a larger less restrictive housing is going to REQUIRE a tune for the vehicle to run properly. Intakes that do not require a tune are often just as restrictive as stock and do not result in large power gains." - VMP
http://www.troyerperformance.com/cgi-bin/ppistore.pl
http://gopowerhungry.com/
That is the common misconception. The effect is on the MAF TF table hardcoded in the tune. The relationship between MAF counts and actual mass airflow being measured is altered with certain CAI's. It outputs inaccurate data. Hence the required manual, hardcoded correction.
It has nothing to do with just being larger or whatever; by merely changing the shape of the intake in that region, or the MAF's location, is enough to pecker this.
The respected tuners have pre-configured MAF TF's on file to essentially 'plug-in' to their custom tunes, for those intakes that they have tested. Each and every intake (save the stock unit), needs this type of empirical data collection if MAF interaction is evident/suspected.
can I ask why you want a CAI?
The reason I ask, without custom tunes, a CAI adds only about 6 to 8 HP. A tuner will do 4 times as much. Spend your money on a tuner. Now a CAI with a custom tune will add about 12 to 16 HP.
Simple - call one of the custom tuners.
Anyone running a full-on CAI - e.g. something like the Spectre, K&N, S&B, Volant, AFE, 3.25 or 3.5" AF1, etc for 04+ trucks, is just asking for trouble.
The fact that there are peeps doing so without a tune, does not mean they are right....
If THAT is going to be your criteria, well.... yer truck. Not smart, IMHO.
Can't afford those phone call? Those tuner folks also have email
__________________________
After reading the above, what part is not clear to you?
everyone in this thread already said that the truck will probably run lean and should get an intake, no one disagreed with ANYTHING you said, but you're still badgering everyone for everything they wrote.
you want proof it can work? I ran my k&n fipk for 35k miles without any tuner and my cylinder head temperatures hovered between 182-191 (under hard running conditions)... if you've done your research, you'll see that these temps are significantly lower than most/all F150s running with stock intakes. low temps = balanced a/f ratios.
why are you going to go and literally de-grade people based on hear-say?
Cylinder head temps are controlled by yer COOLING system. It's EXHAUST GAS temps that you need to worry about, bamby. As running lean causes EGT's to go up. Perf tunes are set up to be on the lean side - a consequence of the tune's requirement to extract more power. Tow tunes, on the other hand, run a little richer - TO CONTROL EGT's, as heavy towing has a tendency to raise those as a function of load. YOU CANNOT INFER ACCURATE A/F's WITHOUT A WIDEBAND TO MEASURE THEM. My god, man - WTF are you thinking????
If yer truck had one of the factory calibrations that had an existing lean (or rich) tendency - it has happened, more than you know - then an uncorrected TF can indeed be very sub-optimal and indeed even hazardous. Folks have had 15:1 -16:1 and leaner factory lean issues right out of the box - this, under WOT conditions, are not good for power, or yer motor over time.
And - it's NOT strictly about running overly lean - it can also be running overly rich - again solely a function of how skewed the TF has become. The MAF CANNOT know what is truly going on if the conditions for which it was initially calibrated, in the STOCK venturi, are disturbed. It's based upon sampling, an then inferring from a table. If the sample is off, the lookup is going to be wrong. With no recourse but a manual tuning correction.
Heasay, you say? Perhaps you should also contact one of the tuners. I got this info from Troyer Performance, and other info over the years all across this board, from acknowledged experts. Sa you do not care to look.
Please - just call a tuner, okay? Hopefully you still have an open mind and are willing to learn. If not, well ... sucks to be you.
I'm done here. The level of ignorance is simply stunning
This is becoming pointless. MGD signing off. Bye folks.
That is the biggest crock of BS I've read in a very long time, and it confirms that you have absolutely NO clue about what you are talking about.
you can either listen to one person's fancy verbage and condescending remarks or listen to everyone else's testimonials and advice.
oh.. and FYI, i guess the entire PHP forum is " the biggest crock of BS I've [you've] read in a very long time, and it confirms that you [I/ PHP forum] have absolutely NO clue about what you [I / PHP forum] are talking about." But yea, what do a bunch of custom-programming tuners and customers know.
http://forum.gopowerhungry.com/gryph...tinky-cab.html
**unsubscribed**
....The MAF CANNOT know what is truly going on if the conditions for which it was initially calibrated, in the STOCK venturi, are disturbed. It's based upon sampling, an then inferring from a table. If the sample is off, the lookup is going to be wrong. With no recourse but a manual tuning correction.....
Can you run a CAI without a custom tune? Absolutely.
Have folks on this forum and other done this without any "noticeable" damage to their engine? Absolutely.
Is it possible to run a CAI without ever getting a custom tune and never experience any noticeable engine issues for the life of your ownership? Absolutely.
Would I run a CAI without a custom tune????? Absolutely not.
The experience others have had with the above combination does not mean it's a good idea nor bad, but I personally would not do this. In no way am I trying to knock the decision of those who have run a CAI w/o a tune.
Your stock tune cannot compensate for something that it does not know has changed.
