Wiring Diagram - Please Verify
Old 05-15-2009, 09:11 AM
pylda's Avatar
Is this information correct?
2008 Ford F150 Truck Car Radio Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Light Green/Violet
Car Radio Accessory Switched 12v+ Wire: Light Green/Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Light Blue/Red
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Orange/Light Green
Left Front Speaker Negative Wire (-): Light Blue/White
Right Front Speaker Positive Wire (+): White/Light Green
Right Front Speaker Negative Wire (-): Dark Green/Orange
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Gray/Light Blue
Left Rear Speaker Negative Wire (-): Tan/Yellow
Right Rear Speaker Positive Wire (+): Orange/Red
Right Rear Speaker Negative Wire (-): Brown/Pink
Old 05-15-2009, 09:56 AM
projetmech's Avatar
did you try doing the search? i know i have seen diagrams and links to diagrams posted in the past.
Old 05-15-2009, 10:07 AM
pylda's Avatar
i tried searching bud, if i had found what i was looking for, then i wouldnt have started a new thread, thanks
Old 05-15-2009, 10:21 AM
05RedFX4's Avatar
I have an 07 and this is what my wiring was
Yellow-12v constant
Red-12v switched
Black-ground
Orange/white-dimmer
Blue-power antenna
Blue/white-amp turn on
White-LF+
White/black-LF-
Green-LR+
Green/black-LR-
Violet-RR+
Violet/black-RR-
Gray-LR+
Gray/black-LR-
Old 05-15-2009, 10:44 AM
yetti96's Avatar
Yellow-12v constant
Red-12v switched
Black-ground
Orange/white-dimmer
Blue-power antenna
White-LF+
White/black-LF-
Green-LR+
Green/black-LR-
Violet-RR+
Violet/black-RR-
Gray-LR+
Gray/black-LR-
Aren't those the standard aftermarket colors? I think the OP means what are the truck's wires colors.
OP, I cannot confirm the colors, but can I ask what you are trying to do?
Old 05-15-2009, 10:50 AM
pylda's Avatar
Want to hook up a Re-q so that I can have pre outs for a sub and front component speakers. The Re-q was a throw in on a deal for a Qlogic box and I figure I will use it until I get my new Kenwood HU.
Old 05-15-2009, 11:08 AM
05RedFX4's Avatar
Yes they are, but they are also what the wiring on my vehicle specific harness plug was. What the wiring that is actually in the truck is, I have no idea.
Old 05-15-2009, 11:49 AM
LightningJMP's Avatar
#513820: 2008 FORD F150 2DR TRUCK WITH 4.2L ENGINE AND STANDARD AUDIO SYSTEM
Audio/Mobile Video
WIRE COLOR POLARITY LOCATION
Battery LIGHT GREEN/VIOLET (+) RADIO HARNESS
Accesory LIGHT GREEN/YELLOW (+) RADIO HARNESS
WILL BE PINK/BLACK ON XL AND STX MODELS.
Ground BLACK (-) RADIO HARNESS
Illumination LIGHT BLUE/RED (+) RADIO HARNESS
LF Speaker (+) ORANGE/LIGHT GREEN
LF Speaker (-) LIGHT BLUE/WHITE
RF Speaker (+) WHITE/LIGHT GREEN
RF Speaker (-) DARK GREEN/ORANGE
LR Speaker (+) GRAY/LIGHT BLUE
LR Speaker (-) TAN/YELLOW
RR Speaker (+) ORANGE/RED
RR Speaker (-) BROWN/PINK
Quick Reply: Wiring Diagram - Please Verify
