Rotate driveshaft 180 degrees
Old 04-16-2004, 09:15 AM
SR89racer's Avatar
it is not hard to do at all i might try it myself this weekend and see i did look under there and notice this is a 2 piece driveshaft now with a carrier bearing in the middle
Old 04-17-2004, 12:33 PM
nadstrebor's Avatar
04 Vibration
After 3 dealers, 2 front rotors, 2 tire balancings, the solution was a new drive shaft.
They referred to TSB 040303
Old 04-24-2004, 04:08 PM
stevenslow's Avatar
I got the Vibration back 2 days after this repair. It is now in the shop a second time to have the vibration a rear end humming noise looked at. I hope this is not a sign of things to come.
Old 04-24-2004, 06:58 PM
dgdee's Avatar
SR89racer... What size bed does your scab have? The Supercrews don't have a carrier bearing.
Old 04-24-2004, 08:34 PM
stevenslow's Avatar
I have a 5 1/2 ft bed and although it has been a few weeks since I was under it, I'm pretty darn sure there is a 2 piece shaft with a carrier bearing.
Old 04-24-2004, 08:37 PM
SR89racer's Avatar
I have the 6.5 bed attached to a Scab! i also towed my boat for the first time and the vibe at 60 is worse taking it out of O/D seems to make it not so bad but is still there.
Quick Reply: Rotate driveshaft 180 degrees
