cruies control
cruies control
cruise control went out last night? looked under hood and the sensor on end of master cyl. was leaking brake fluid got new one still no cruies? checked all fuses all good. ran self-test diagnostics light goes on while holding off button and on button move to other side resume,coast,set-acel nothing where to go from here? the horn dose work. any suggestions thanks
just went out and looked there is a ball of wires all zip tied and there is a fuse in there a 2 amp it is blown will go get one and try just hope it blew from all the brake fluid coming out of old switch. i should of seen that? i'll let you know thanks
