AC Bypass Option
Old 03-22-2013, 02:00 AM
SaveMy150's Avatar
AC Bypass Option
97 F150 4.6L
Just finished bypassing AC, replaced smooth idler pulley with grooved (Gates 38052 equivalent), shortened the belt to the non-AC length of 79.7” and rerouted over idler pulley. A bit tight but all clear. Another site noted the Gates 38053, smaller diameter was used, and another used a slightly longer belt 81 1/8”. Removed AC pulley (bearings failed) and coil, will replace if it ever gets hot enough.
Old 03-22-2013, 08:52 AM
crash_lucky13's Avatar
do you still have the stock pulley fan? have you had any issues running hot? awesome man glad it worked out for ya!
Old 03-22-2013, 04:02 PM
SaveMy150's Avatar
I only bypassed AC pully (removed, but compressor still in place) by replacing the idler pulley and routing new belt over top instead of under, all other belt routing is the same. Not sure what you mean by stock pully fan. Don't anticipate issues running hot, will know more with time.
Old 06-28-2016, 12:43 AM
dakotadave's Avatar
THANK YOU SAVEMYF150 FOR YOUR INFO ON THIS! Used a differint pulley and the same belt size you recommended and now me wife's truck runs again! YOU DA MAN!!!
Quick Reply: AC Bypass Option
