285/75/16
Old May 27, 2002 | 11:46 PM
97_F150_Tan's Avatar
Question 285/75/16
Hi, I'm looking to give my truck a nice stance and would like to replace some 225/75/16 tires with some 285/75/16 tires. My question is how well will they fit on stock rims? Are they going to be too wide for stock wheels. Also is there going to be a problem with rubbing and if so is it a big deal? (I have a 2wd truck) I have about an inch above stock ride due to some coil spring spacers.
Old May 28, 2002 | 08:35 AM
Petrol's Avatar
Re: 285/75/16
is yours the current 'new' body style F150?
are you sure about the 225/75-16 OEM tire size? I thought that with the new body style Ford went to 255/70-16's
one of my neighbors has a 98 F150 4WD with 285/75-16 BFG A/T KO on the factory rims, no lift kit, no rubbing or other problems.
a guy at work has a 97 F150 with 235/85-16 Michilin XLT's and no problems.
Old May 28, 2002 | 06:46 PM
Yes it's the new body style, a 97. Also yes the tires are 225/75/16, they are not original tires. A previous owner put them on it.
Old May 28, 2002 | 07:35 PM
Petrol's Avatar
I can't explain why anyone would put such a small puny tire on that truck other then he replaced the worn out OEM size with them so he could say 'It has new tires on it too.'
you can run the 265/75-16's with no problems at all, your speed-o-meter will be about 3 MPH slow, but then it's likily 5-7 fast now (reads 65 MPH when your going 60 MPH) and that could take some getting used to.
Old Jun 1, 2002 | 11:37 PM
Silver&Blue's Avatar
I had a 94 F250 4X4 Heavy Duty and I put 285/75/16 on stock sized rims and they rubbed. I had to do some shimming to get them not to rub on turns. Petrol says his neighbor has this setup, but it is hard for me to beleive they don't rub, I am willing to bet on a 2wd they will rub. But maybe the new trucks have more room than I am thinking.
Old Jun 3, 2002 | 03:55 PM
Lemual's Avatar
I put 285/75 -x 16 on my 7 in. wide wheels. They look great and there is no rubbing or anything adverse. I don't have a lift and it fits fine. I do run about 6 mph slower. 59 on the speedometer is actually closer to 65.
Old Jun 6, 2002 | 01:05 AM
powerstroke73's Avatar
Big difference there bud. You're comparing a 96- to a 97+. Thats comparing apples to oranges. They opened up the wheel wells enough in the body change where you can fit tires like that. From what I've heard you can put them on a stock 2wd with very minor rubbing.
Old Jun 9, 2002 | 10:30 PM
HCAbowman's Avatar
Im runnin 285's on my 98 4x4 x-cab, speedo is about 9,ph slow, with no rubbing on stock rims....not too much longer and she will be sittin up on a 6" lif t on 35's!! Whoooo hooooo
