33" tires on 1992 4x4
Old Apr 8, 2002 | 07:54 PM
92Custom's Avatar
I have the stock size tire on this truck - and they look tiny...there is a ton of room in the wheel wells.
what are your experiences with trying to fit 33" tires on a stock 92-96 4x4?
I am looking at a 33x10.50x15 or 33x9.50x15 because I know a lot of the clearance issues come from the wider 12.50 inch tires. I also want to keep the stock wheels.
I know that I can shim the front bumper out for clearance if needed..
give me your thoughts
Old Apr 9, 2002 | 02:00 AM
Donate54's Avatar
you might be able to get away with it of you dont go any wider than 10.5. it might be close, though.
Old Apr 9, 2002 | 03:43 PM
J-150's Avatar
I have seen a million and one pre-97's with 31 x 10.5 (2wd and 4x4). I have also seen a number of 4x4's with 33 x 12.5 (pretty well all 4x4). As far as I know, there should be no clearance problems.
Old Dec 14, 2002 | 08:40 AM
ls1powr's Avatar
If you don't want to lift it, I think 31x10.50 (or maybe even 11.50) is the best you'll be able to do. I put a 3" body lift on my truck and my 33x12.50's still rubbed. But it only took about 2 minutes with my sawzall to cure that problem. All I had to do was cut out the inner lip of my front bumper and the black valance underneath it. Haven't had a problem since.
