17" vs 18"
I did a search and everything was for 4x4's and lifted trucks.
Note: tires must have good characteristics in dry, wet and snow (Michigan weather). Are there any good all season tires that will fit on 18" 2002 Lightning wheels? Most tires I see are "street truck" which means I'll probably be SOL in the winters here. They would be put on a 2002 F150 4x2 no lift. If not, what is a good all season tire (biggest size possible) that would go on a 17" wheel that will fit.... ... under the stock suspension? ... with a 2" suspension lift? |
Take a look at this link. It is the results of the street/sport truck tires. http://www.tirerack.com/tires/surveyresults/sst.jsp
You can also see what sizes they all come in. |
tirerack.com is where I got all my info from (in hindsight, i should have mentioned that).
