Will 99 Lightning wheels fit 01 SCrew?
Old Jan 5, 2002 | 06:36 AM
HI SCREW's Avatar
Anyone swapped their stock 01 SCrew wheels for 99 L wheels? I've read that early 99 L wheels are different and that only late 99 L wheels will fit on 99-Up F150's.
Thanks in advance for your help.
Aloha From Hawaii
Old Jan 5, 2002 | 11:03 AM
Crum's Avatar
It has something to do with the 12mm versus 14mm lugs.
Here's a good example....
http://www.oemfordparts.com/partdeta...&CategoryID=49
I just ordered the M-1007-M189 for my Screw Thursday.
Old Jan 6, 2002 | 02:18 AM
Syeth's Avatar
What price will you be getting these 99 L wheels for ? If its cheap enuff i say just get em and some 12 mm lugs and have at it. If it does not fit because your posts are bigger try bringing it to a rim and tire place im sure thay can make the hole bigger. All im saying is if your getting a good price on these wheels just go for it and if all else fails you can allways sell em back for as much as you bought em for.
Good Luck
Syeth
Old Jan 13, 2002 | 02:22 AM
veloci's Avatar
Hi Screw, you will be fine with the 99 L wheels. i installed a set on my 2001 Supercrew and no problems. they fit a little tight but youhave to do no modifications at all.
