35" tires
Old Dec 30, 2001 | 02:55 AM
KingRanch01's Avatar
Question 35" tires
I have a 2001 Supercrew with 35" on 16 x 8. And i would like to know if they will fit under my truck with 16 x 10? I have a 5" RCD lift under it. Any input would be nice. I am mainly wondering about the turning clearance. Thanx
Old Dec 30, 2001 | 05:20 AM
BigBadRedLiftedFordMan's Avatar
If i understand correctly that you have a 5" lift and are running 35x12.5R17 or 35x12.5R16.5 or the metric 315/75R16, then you should have plenty of room for the 16x10 as long as it has no positive offset (Most 16x10s wont...a negative offset, which is what you want, means that the wheel appears "deeper"). I have only a 3" body lift, and i have 35s on 16x10s, they rub very rarely, and i mean, like only when i hit bumps or driveways too fast, at too much angle. But i am positive that with another inch or 2 i would have plenty of clearance. And since you have 5" (not 3 like me), then my point is yes. Yes, they will fit. Hope this helps.
