Ford Outfitter
Old Dec 28, 2001 | 09:36 AM
jeremyb's Avatar
Ford Outfitter
So you don't have a lift on your truck?? It looks like it clears the tires extremely well...Does it sit higher then my '97 offroad stock or something? I was getting ready to buy 16x8 589's with BFG 285/75's but I like the wide stance of yours much better! Thanks
Old Dec 28, 2001 | 06:31 PM
2-Tuff's Avatar
Ford Outfitter
I agree with jeremyb, I like the looks of your setup. I want to do the same to mine. My only concern is that I pull a 4700lb travel trailer with a weight distrubution hitch. It might set the screw down a couple inches all around. Based on your setup, does that seem like it could be a problem? Thanks.
Old Jan 3, 2002 | 12:55 PM
ChaoticRacer's Avatar
Ford Outfitters truck looks good. I'm going to run the same wheels and tires when I get a new truck. I don't think there would be a problem with the trailer. If there is, its nothing a AAL can't fix
Old Jan 4, 2002 | 01:54 PM
FALLSCREW's Avatar
Ford Outfitter,
Do you have any side view pic's of your truck ? I would like to see haw the 589's look from the side view. Great stance on the truck!
