Wheel Centering
Old Oct 26, 2001 | 07:01 PM
TubaMan's Avatar
Wheel Centering
how big of a selection of rims is there for the 4x4 f150's? mine center on a hub that is on the rotor & rear axle, and when i need to get a rim off, it's always siezed on... (i'd like to beat the genius who decided the centering should come from the hub, and not the lug nuts)
Old Oct 27, 2001 | 06:20 PM
MKTRUCK's Avatar
25 Year Member
Rule of thumb. CAUTION!!!!!!!!!!!
If wheel is stuck on HUB. Loosen wheel nuts, and run up hand tight. Perform a series of figure 8's in an abandond parking lot, and then you should be able to remove them. Drive slowly. That is what I read years ago in regards to this. The easiest way is just make a few circuits of your block and then pull the wheels off.
AGAIN, CAUTION!!!!!
Mike
