2014 Brake problem
Old Sep 24, 2019 | 01:19 PM
nu-supercrew's Avatar
2014 Brake problem
On sons 2014 f150 4wd, right front rotor getting gouged. Replaced caliper, pad and rotor and still have exact same problem. Where do I look next? Brake line? ABS module?
Old Sep 24, 2019 | 08:37 PM
Cheapest is brake line and bleed the system.
Old Sep 24, 2019 | 09:40 PM
Thanks Manual F150👍
Old Sep 25, 2019 | 12:38 AM
jgger's Avatar
Make sure the pads aren't bound up, they should be able to rattle just a little in the holder. I had some Auto Zoo pads that were too stiff in the hardware and ate the and a rotor in a couple of hundred miles. The tabs on the pads measured about .003 to .005 bigger than the clips they are supposed to slide in. I filed down the new ones and all is fine.
Old Sep 25, 2019 | 01:31 AM
MitchF150's Avatar
Looks like your caliper slides are sticking? Or just something just ain't right...
I'd take it all apart and check out the slides, pads, rotors, etc...
I did this upgrade a couple of years ago and haven't looked back.. Still the stock calipers and slides, just the Power Stop rotors and pads.
Mitch
Old Sep 25, 2019 | 12:21 PM
Thanks for those great suggestions. Working on it Saturday. Will post results.
Old Sep 29, 2019 | 04:23 PM
The brakes were done last year. Had no problems until this. We took it all off and back on, still same result. The brake line is in good shape on the outside. I am thinking it must be a bad solenoid valve in the ABS module.
Old Sep 29, 2019 | 04:32 PM
Most brake line issues result from the opposite.
Old Sep 29, 2019 | 08:53 PM
The brake line may be collapsing on the inside.
Old Sep 29, 2019 | 10:38 PM
Roadie's Avatar
Did you remove the pins that the caliper slides on, clean, and lubricate them?
