2013 Platinum offset issues.
Old Jan 4, 2018 | 05:49 PM
jmcninc's Avatar
What size spacer is needed to clear 33x12.50x20 nitto mudgrapplers on a 2013 Platinum 4x4 with a rancho quick lift? I know the 12.50 for the graps are actually 12.8" wide so from stock it's just going to slightly rub the UCA. Would a 1/4" spacer be enough to clear so it can ride? I'm currently running 275/55/20s that came with the truck. After doing the math I know the grapplers will add 1 inch on each side.
Old Jan 4, 2018 | 06:03 PM
Getting wheels with the proper offset is a lot safer than spacers.
Old Jan 4, 2018 | 06:10 PM
jmcninc's Avatar
I can understand spacers over 1.5" being an issue but I'm definitely not going to cheap out and get non hub centered spacers nor get anything over 1.5". Mainly want to know if anyone has run the 1/4" spacers with success
