Front End Vibration
Old Sep 22, 2017 | 12:51 PM
BlueOvalFitter's Avatar
Question Front End Vibration
2007 F 150 XL, 4.2 V6, 140K miles
Back in June 2017 I had new tires put on my truck. I noticed a vibration in the front end ONLY at 50-53 MPH. Actually, it's more pronounced at 51 MPH.
I brought it back to the tire store and they checked the balance on the front tires. They were still balanced ok. So, they switched the front tires from side to side and went ahead and re-balanced the rear tires while I was there. Only 1 tire needed to be re-balanced on the rear.
So, off I went again. As I approached 50 MPH, here comes the vibration again. I do know this for a fact, that the previous tires NEVER gave me any problems. I had to replace them because they were showing signs of dry rot. They were starting to get cracks in them.
Anyway, I was thinking that if they switch the front tires to the back, back tires to the front, and the vibration stops, it can only mean 1 of 2 things;
1) A bad tire.
2) A bent rim.
Opinions, please?
Old Sep 22, 2017 | 02:03 PM
The tire store should be able to find a bent rim or bad tire. The tires may need road force balancing.
Old Sep 22, 2017 | 02:50 PM
Thumbs up
GLC, you might have something there. When I first bought my F 150 in 07 there was a slight vibration somewhere on the truck. The Ford tech took it for a test drive with a WDS machine. The machine tracked it to somewhere in the right rear. Back then there was a vibration damper kit Ford would install on the frame to cure this problem. Well, they installed one, but the vibration was still there. They then did the road force balancing to ALL of the tires. Vibration gone!
