Grinding noise when turning left
Old Aug 9, 2017 | 09:18 PM
Ford4242's Avatar
2010 f150 4x4 makes a loud grinding noise only when turning left. It only happens when in 2wd. 4x4 functions fine and the noise goes away. I was thinking it might be the IWE Solenoid issue but my problem seems backwards, given that it works in 4wd but not in 2wd.
Suggestions?
Old Aug 9, 2017 | 09:46 PM
If you are in 2wd and are losing vacuum, the IWE *WILL* grind. This sounds more like a problem with the IWE itself, not the solenoid. Troubleshoot the system using a handheld vacuum pump.
