Stay with 265/75R16 or go 245/75R16?
I can't decide for my next set of tires if I want to stay with the 265/75R16 or drop to a 245/75R16. I like the look of the 265 tires but they take away some of the engine power on hills. I definitely don't want to go any smaller that a 245. Considering the difference in diameter is only about 1 inch, would going with the 245 size result in any noticeable power gain or would the change not really be noticeable?
My engine RPM is almost identical with the Y2K @ 3.73 and LT245/75R16 as it was with my '97's 3.55 P255/70R16.
I was expecting better performance with the 3.73 -- however the additional leverage was used up with the larger tire size.
I suspect that you'd notice the smaller tire size at cruize (especially if you tow) and 0-10, but nowhere else.
Originally posted by 2001 F-150 SPORT
Isn't 245 the width? 75 is the height of the top of the rim to the top of the tire.
black truck,
you may already know this, but i haven't seen it mentioned. all of the 245 tires i have seen were 10 ply. they are made to tow with, or haul heavy loads. the 265 i am running is a 8 ply. still stiff enough for the hauling i do, but lots smoother than the 10 ply tires. just something to think about, Rich.
