How big may I go with out a lift?
Old Sep 7, 2001 | 12:42 AM
jcsingle21's Avatar
Question How big may I go with out a lift?
I wanted to know how big I could go with just factory settings or just raising the front torsion bars? I have a 1998 F-150 4x4 Off Road. I am willing to buy new rims! I was told I was able to fit some 33's but I am not sure! GIVE ME SOME INPUT!!!!!!!!!!
Old Sep 14, 2001 | 04:36 PM
Dargo's Avatar
Alot of people are running 285/75/16 or 305/70/16 with no problem. they are both equivelent to a 33. I have also seen a couple of trucks running 315/75/16 with a little torsion tweak. They are 35 inches tall.
Old Sep 14, 2001 | 04:44 PM
iamhakiem's Avatar
I had to put a 3 inch body lift on mine to get 33x12.50 tires on it.
I also had to trim about an inch off the lower part of the plastic below the bumper.
99 4x4
Old Sep 14, 2001 | 05:01 PM
Georgia Cracker's Avatar
I have asked, or seen asked, questions along this same line. Wandell told me with the 285s, you have to trim a 1/4 to 1/2 inch off. For 305s, a fella told me he took about an inch off. That is with 16x10 rims. With 16x8s, you don't have to trim at all to fit 285s. Hope this helps.
Old Sep 16, 2001 | 02:12 PM
Stump-Jumper's Avatar
Talking Sizes
I put my 305/70R17 (or 33.8 inch) tires on my truck before my lift kit and they fit fine. The only difference in your truck and mine appears to be rim size. I have the stock 17 inch rims. They didn't rub and I didn't have to trim anything. I didn't adjust my torsion bars either.
Old Sep 17, 2001 | 02:04 PM
meek47's Avatar
I am running 285/75/16 Bridgestone Dueller A/T tires with no problem. When I bought the truck used about a 16 months ago it had 33x12.50 Super Swamper TSL Radials on it. That was on the current wheel. I, like Dargo, have heard of several people on the board in the same situation as myself. I hope my next set will be BFG M/T KM's...the new one. I hope to put 35's on with a lift, but due to insufficient funds, I doubt that will happen. Probably end up with 33's. Good luck, Meek
Old Oct 8, 2001 | 12:55 AM
jcsingle21's Avatar
Question I want 33x12.5 15LT think it will work?
Yes i was wanting to put some 33x12.50 15LT on my truck. I am hoping I won't have to trim or raise anything. The tire I would choose would be BFGoodrich All Terrain T/A KO's or the new Radial Mud-Terrain T/A! Do you think it will fit on my rig? I hope it does I am almost ready to buy! Thanks!
Old Oct 8, 2001 | 07:55 AM
MAC[H]Z's Avatar
I am going to install a set of 33x12.50x16.5 tires in a week or two so if you haven't installed by then I will let you know how they fit.I have a 98 ext cab 4x4 and I asked the same question and got conflicting results so I am gonna try it anyway to see what happens.
good luck
Old Oct 8, 2001 | 12:39 PM
jcsingle21's Avatar
Talking let me know
Dude let me know how it works out and email me if you can at jcsingle21@yahoo.com Thanks
Old Oct 8, 2001 | 04:06 PM
MANDRAKE27's Avatar
Smile 285/75/16's on 16x10 factory alluminum
Hi there! I have now put 35'000 km's on my BFG 285/75/16 AT's with VERY little wear and absolutely no rubbing.....this including situations under maximum suspension flex! I would recommend this mod to anyone. As an added bonus...on flat straetches, when travelling near the speed limit, I have noticed an improvement in mileage. This is NOT the case however in the city, or driving at "normal" hehe highway speeds. Good Luck!
Old Oct 15, 2001 | 09:45 PM
footwart's Avatar
i have a 97 f150 with the 17 in. factory wheels and tires. ive asked the same [?] and also got mixed answers. im putting on a 3 inch body lift and 33x12.50 tires on 15x10 rims. some people said 35,s would fit with no lift others said a lift for 33,s. im going to bypass anymore confusion. good luck
Old Oct 16, 2001 | 10:59 AM
powerstroke73's Avatar
Hope you got rims with a small backspacing if you went with the 15s. I'm still trying to figure out why everyone wants to run 15" rims on their trucks. Virtually all tire manufacturers are making more and more 16" tires. Heck I was looking on Interco's website and of all the new tire sizes they listed most were for 16" rims.
I've been running 285/75/16s on my factory rims for about 9 months and have not had a single problem with them. I can't get them to rub at full articulation. I don't have a picture of the other side, maybe in the video that John shot. But the tire wasn't rubbing anywhere in this shot.
Old Oct 17, 2001 | 02:59 PM
footwart's Avatar
your right about the 15 inch rims. the offroad package has larger calipers and the rims wont work anyway. so in the long run i did go with the 16,s
Old Oct 20, 2001 | 02:52 PM
footwart's Avatar
hey,i put a 3 inch on my 97 offroad with 315 75 16 tires. had to trim the lower valance under the bumper but other than that no problems. if you have a or package on your truck, i found out the 15x10 wont fit because of the calipers.
Old Oct 23, 2001 | 02:30 AM
TWERNER's Avatar
I have a set of 15x10 wheels on my 4x4 ORP. They fit but the wheel is within an 1/8th of an inch from my front brake caliper. So if you run 15 inch wheels be careful of the placement of sticker weights for balancing.
33 inch tires will fit, without rubbing, on the stock wheels. Aftermarket 4x4 wheels usually have more backspacing which makes them set out wider on the truck, this is where you will have your problems with the 33 inch tires.
