lug pattern
Old Nov 13, 2013 | 11:13 PM
KingRancher18's Avatar
lug pattern
Alright.I gotta 02 F150 supercrew fx4 what is the exact lug pattern is it 5x5.5" or 5x140mm or are they the same? Lol this is bugging me.and could I fit 5 lug f150 90s model on my 02? Thanks for any intel
Old Nov 13, 2013 | 11:20 PM
2000 and earlier are 5 x 5.5", 2001 and newer are 5 x 135 mm. Not interchangeable.
Old Nov 14, 2013 | 12:03 AM
pizzaman711's Avatar
96 and earlier are 5 x 5.5", 97-03 are 5 x 135, but like you said they aren't interchangeable.
Old Nov 14, 2013 | 04:28 AM
svt2205's Avatar
And in 99 Ford upsized the lug size from 12 to 14mm, so early be careful about trying to fit the earlier wheels to your 02. If you end up considering that route too.
Old Nov 14, 2013 | 08:59 AM
Beastly_95's Avatar
2000 was a split year for lug sizes early 00 models had a 12x1.75 bolt size and later models had the 14x2.0 RH
Old Nov 14, 2013 | 10:13 AM
Wheels still fit the same, just requires the lug nuts that are made for his years stud.
Old Nov 14, 2013 | 12:39 PM
Then the site I used is wrong.
http://www.discountedwheelwarehouse...._Reference.cfm
2000 Ford F150 Pickup 5 lug 5.5 inch or 139.7 Standard Offset
2001 Ford F150 Pickup 5 lug 5.31 inch or 135mm Standard Offset
Old Nov 14, 2013 | 12:58 PM
Beastly_95's Avatar
I owned a 2000 and the lug pattern was 5x135mm same as the 98 I have now? and my friends 03 has the 5x135mm lug pattern as well
Old Nov 14, 2013 | 01:12 PM
kingfish51's Avatar
It is definitely wrong. Might want to keep this site as a favorite. It does not have everything (like the 7700/8200 7 lug pattern), but seems to be correct for everything else.
http://www.myboltpattern.com/
Old Nov 25, 2013 | 10:07 PM
fnnrNArnner74's Avatar
ya definitely wrong on that 2000.. 97-03 5 lug 5x135
