will this setup work
Old Oct 18, 2013 | 07:01 AM
acosta19d's Avatar
Im looking at buying a new set of wheels and tires but need a little bit of help. I have a 2006 fx4 with a 6in procomp lift. Right now the truck is on 33s with 16inch wheels. Im looking to upgrade to 35s and a 17inch wheels. Do you guys think there will be an issue with turning or rubbing? Im looking to get the nitto dune grapplers in a 305/70/17 with the xd addicts in a 17x9 with an 18mm offset 6x135.
Thanks for the input
Old Oct 18, 2013 | 12:27 PM
wandell's Avatar
How are you running a 16 inch wheel on a 2006? Surely you have some sort of wheel/bolt pattern adaptors since no one has ever made a 16 inch wheel in the 6x135mm bolt pattern as they won't fit over the brakes. Did you have to grind down the brake calipers? Just curious.
Old Oct 18, 2013 | 03:32 PM
acosta19d's Avatar
I honestly dont know the wheels are from american racing ill have to look into that. Thats how I bought the truck so ill know wats going on once I take these wheels off.
