Any problem going bigger?
Old Oct 7, 2013 | 01:33 PM
Downrange's Avatar
I currently have an 09 f150 XLT 4x4 crew cab. Looking at putting a 2" leveling kit on it and going from 275/65/r18 to 295/65r18 duratrac tires. Does any one know if there are any known problem doing this? Or would I be better to stick with the same tires size? I worry about tire rub or a difference in the speedometer or any safety feature. please help!
Old Oct 7, 2013 | 01:50 PM
mdhawkin's Avatar
You will be fine going to that setup. You should not have any rubbing issues, minimal loss in performance and gas mileage. The difference between those tires in size is not that much - unsure on weight.
