4runner wheels fit ?
Old Aug 23, 2013 | 07:20 PM
tt64vert's Avatar
Im looking at buying some eagle alloys off a newer toyota 4runner , will they fit?
Old Aug 23, 2013 | 07:34 PM
kingfish51's Avatar
No, they have a 6x5.5" (139.7mm). Yours are 6x135mm.
You can check bolt patterns here.
http://www.myboltpattern.com/
Old Aug 23, 2013 | 08:15 PM
tt64vert's Avatar
Eagle doesnt make a 6x139.7
Old Aug 23, 2013 | 08:30 PM
pizzaman711's Avatar
It's the same as 6x5.5. Either way the only wheels that'll fit your truck will be off of a 04+ f150.
Old Aug 23, 2013 | 10:37 PM
tt64vert's Avatar
Wheels fit...multi pattern ...just need a hub centric spacer
Old Aug 23, 2013 | 10:45 PM
kingfish51's Avatar
Are you saying the wheels have multiple bolt patterns drilled in them? I doubt that very. The wheels may be available for different patterns, but would only be drilled for the 4runner pattern, which will not fit your 04. If it truly does have multiple patterns drilled in, it would be a cold day in hell before I would put them on my vehicle.
Old Aug 23, 2013 | 11:53 PM
Why would you need a spacer for them "even if they were drilled in your pattern"? That should be a red flag right there that they aren't right for your truck.
Old Aug 24, 2013 | 12:17 AM
tt64vert's Avatar
They are drilled in 6x135 and in 6x5.5
Old Aug 24, 2013 | 12:32 AM
I've seen multiple wheels with two patterns drilled in them . . .
If they're drilled for 6x135, why would there be any issue with them fitting?
Old Aug 24, 2013 | 12:41 AM
tt64vert's Avatar
Old Aug 24, 2013 | 12:43 AM
tt64vert's Avatar
i think i need hub centric rings cause the bore is too big on the wheels
Old Aug 24, 2013 | 12:46 AM
tt64vert's Avatar
Old Aug 24, 2013 | 09:45 AM
kingfish51's Avatar
Not a problem with fitting, but with strength. You now have lost a lot of metal and strength exactly where they really need to be strong. Plus with all the holes, they look like crap.
Old Aug 24, 2013 | 10:40 AM
tt64vert's Avatar
Center cap covers holes
Old Aug 24, 2013 | 01:11 PM
The strength part I definitely agree with. Most others I've seen were 5 lugs with much more space in between each hole. I don't like how thin those lug hole walls are.
The holes are fine looks wise though, because the caps cover them.
They look good though!
