ABS & BRAKE lights staying on... NEED HELP
So last week my ABS & BRAKE lights just randomly came on when I cranked my truck one morning. Brakes still seemed to work fine. My brake fluid was full. I replaced the ABS fuse which was blown and the lights went out. Tonight after cranking my truck the lights were back on...
Yall think this is the ABS differential sensor?? Help appreciated!
...oh and my back-up lights are also out!!
Okay I've been searching the forums and I'm seeing it could possibly be something to do with the PCV heater or wiring causing a short which then in turn blows #14 fuse.
Will check in the morning!
