+35 offset ??
Old Nov 28, 2012 | 09:44 PM
04wPotential's Avatar
+35 offset ??
anybody know what 35mm offset looks like on a 04 wiht a 2/5 dropkit
Old Nov 28, 2012 | 10:04 PM
worm5932's Avatar
I had 20x8.5s with a 35 offset on my 04 and I ran a 265 50 20 to keep from rubbing. That was with a 3" drop, 2wd. There are pictures in my gallery. the silver truck
Old Nov 28, 2012 | 10:08 PM
did they stick outside your wheel wells?
Old Nov 29, 2012 | 12:39 PM
wandell's Avatar
In you PM you said the wheels are 9 inches wide. That works out to be 6.38 inches of backspacing. You should be fine. I have 22x9.5's with 6.79 inches of backspacing/ 40mm offset and 305/45-22's.
Old Nov 29, 2012 | 12:41 PM
wandell's Avatar
A couple more.
Old Nov 29, 2012 | 07:27 PM
worm5932's Avatar
No. They didn't they were right at even. I thought for sure they would rub, the only time they ever touched the truck was on the highway if you would get a good dip they would go straight up and kiss the fender liner. Right in the middle of the tread.
Old Nov 29, 2012 | 11:12 PM
jerrybizzle's Avatar
That should be real similar to stock in regards to how far they stick out.
Old Nov 30, 2012 | 12:22 PM
wandell's Avatar
Yeah, they will stick out about 1/2 inch more than a set of OEM 20x8.5's or 17x7.5's or 18x7.5's.
