HELP: 2011 FX4 rims
Originally Posted by jrdn003
so im getting a 2011 fx4 and i am wondering if 17'' rims will fit on them since they have oem 20''.
can seem to find a straight answer on the internet
thanks guys
thanks guys
Posted from F150online.com App for Android
He's wrong, but, what rims do you have? Aftermarket or Ford rims. If Ford rims, what are they and from what year. There are some Ford FX4 rims from 2004 and maybe 2005 that will not fit 09 up. Not because of diameter, but from the calipers actually hitting the spokes of the rim.
Edit - I hope you had tire pressure monitor sensors put on those tires/rims. Otherwise you are in for another surprise.
i dont absolutely need them right? the only thing is that the light will always be on?
It is a bit more than a light. You probably will get the chimes and a message in the message center.
Not super expensive. For my 09, it cost me about $150 for a set of 4 with the valve stems (you need special valve stems to mount them on). Take a look at Tasca or Ford parts. They should be listed under electrical if I remember correctly.
Edit - Just checked Tasca, list is $83 each, they are asking $50 each.
