Ride Difference going to LT tires
Old Oct 20, 2012 | 06:47 AM
klhmn's Avatar
Looking at Terra Grapplers would there be a noticeable difference in ride between LT tires vs P rated tires? Got the OEM Goodyears on my 10 F150 4x4 now. The air pressure is quite a bit higher
Old Oct 20, 2012 | 07:36 AM
sam1947's Avatar
LT tires require a higher psi due to stronger sidewall and tread construction. The trade off is that you lose the 'soft' ride characteristics of the P rated tires. It all depends on what you will be doing with your truck ie: heavy loads or towing, also doing off roading often. I have a set of the Terras on my truck with the P rating and the ride is nice using the 35lb recommendation.
Old Oct 20, 2012 | 07:38 AM
klhmn's Avatar
Yah its basically going to be a road truck. What size are those on your truck? How about wheel size?
Old Oct 20, 2012 | 07:50 AM
sam1947's Avatar
Nothing special, they are 275/65-18 Terra Grapplers, pretty much stock size. Wheels are the XD Monsters 18X10
