2010 Offset Help
2010 Offset Help
I tried the search engine, info overload. 2010 F150 Screw 4 door, 4x4, Chrome Package 6 1/2' box
Ok I like the chrome ATX wheels, going to stick with 18" wheels same diameter tire for the most part, wider profile than OEM tires. which of the wheel sizes should I get? Offset?
http://www.atxwheels.com/wheels/?whe...id=5&groupid=6
18" x 8" +35
18" x 9" +0
18" x 8" +35
18" x 9" +0
The OEM 18" is 7.5" +44. That being said, is the truck leveled/lifted - plans in the future? If you want an aggressive look (tires past the fenders, go with the 9" 0 offset. If you want a bit nicer looking then stock but still under the wheel well - go with the 8" +35.
