325/65/18 06 screw lariat stock wheels 2.5" lk
Old Jul 3, 2012 | 07:58 PM
hkp's Avatar
hkp
got this truck on friday, i like it so far, couldnt leave it alone so i just did the necessary things first...... level it and add tires. so far its good, little rub at full lock in reverse but it was to be expected. now time to start doing all the maintenance ****, i bought a warranty from the small dealer i got the truck from and intend on using it. heres a pic from right after i got the tires put on.....
i will try to get some with my proper camera in the next couple of days.
Old Jul 3, 2012 | 09:26 PM
jdc48160's Avatar
325's on stock width wheels is too wide. Those things are gonna be pinched and wear out the center of the tires.
Good luck with that!
Old Jul 3, 2012 | 09:37 PM
hkp's Avatar
hkp
i guess, ive done it before and didnt have an issue. its bound to get better tire life than a bmw and the tires are cheaper for the truck as well.
Old Jul 4, 2012 | 01:02 PM
wandell's Avatar
True, the tires are a little wider than recommended. Try to run the tire pressure on the low side for daily driving (maybe 35-38 psi). Just be sure to pump them up when you tow/haul a load.
