No brake pressure....then brake pressure...??
Old Jun 29, 2012 | 02:13 PM
TeeF150's Avatar
I was driving around at lunch and started to notice that my brakes were loosing presure and had to push the pedal to the floor to get it to stop. I typically drive to a shady tree and eat lunch in the truck while its idling.
After letting it set for an hour or so I went out at 2pm break and checked the fluid level then started it up. The brake level was full and good pressure. Weird.
Its a 2003 4.6L V8.
Its very hot and humid here today almost 100 degrees so I had the A/C running too.
Any ideas on what it could be?
Its hard to fix something intermittently.
Thanks for any info.
Old Jul 1, 2012 | 02:31 AM
crazymike's Avatar
Might outta look at your brakes for uneven wear. I've had cars do the same thing when the hardware sticks.
Old Jul 2, 2012 | 12:14 PM
mkosu04's Avatar
could be some contamination causing occasional internal leakage in the master cylinder.
If something gets under the seal it can cause a soft pedal, but then that "something" moves out from the seal and your pedal feels fine.
Perhaps try bleeding with fresh fluid to get it cleaned out.
