20" rims.. which tires.. need ur guys help fast..
Old May 14, 2012 | 11:00 PM
boomer1's Avatar
i am gettin some tires tmrw for my 08 f150 2wd with a 2" leveling kit on the front.. right now im running 275/60 with no problem but there not filling up the wheel wells like i want.. what size should i get.. im looking at either terra grapplers or cooper zeon...????
Old May 14, 2012 | 11:18 PM
worm5932's Avatar
305 55 20. Or 33 12.5 20
Old May 14, 2012 | 11:19 PM
06F150CFCT's Avatar
You want wider or just taller or both? You have the stock 20's?
275/65/20 (34.1 x 10.8) Nitto Terras come in this size.
285/65/20 (34.6 x 11.2)
I think the 275/65/20 would be best. I forget how much difference the 2wd is with a level than the 4wd with a level. Thats nothing a little searching on here cant fix for you though.
After a quick search I couldnt find the Coopers in a taller tire than you already have. They have a wider 305/55/20 but thats all I could find just quickly searching ebaymotors.
Correction : After re-searching for largest you can go on a 2wd with a 2" level, it looks like 33x12.5......MY BAD
Old May 15, 2012 | 12:06 AM
boomer1's Avatar
Thanks for the input!! Id rlly like as tall as I can get!! I wouldn't care to go wider but I don't wana go so wide it looks stupid!!!
