31-33" tires?
Old Apr 18, 2012 | 03:04 AM
WillfromNorCal's Avatar
31-33" tires?
I have a 99 Supercab 2wd that has about 1" lift in the back from an AAL and I'm putting on 1.5" spacers in the front soon. I want to beef up the tires a bit so I was wondering whats the best size tire I should run with. Can I clear 285/75/16s or should I go smaller with 275/75/16s or even 265/75/16s? I don't want to regear (have the 5.4 btw) as I only tow about 1600lbs a couple times a year. Thanks.
Old Apr 18, 2012 | 09:11 AM
pizzaman711's Avatar
Since your only going up about 1.5" I would go with the 275/75/16. It's pretty close to the same height as the 285 but it's a little more narrow so you should be better when it comes to not rubbing. You might see it rub a little when hitting bumps and turning at the same time however.
Old Apr 18, 2012 | 09:40 AM
LonestarROB's Avatar
I don't know what, if anything, is different between a 99' and an 08' but I run 33" (275/70/18) Red Letter General Grabbers on my 2wd. All I have is a 1.5 AS level in the front. They fit EASY. Not close to rubbing anywhere.
Just my 2 cents.
Rob
Old Apr 18, 2012 | 09:52 AM
kingfish51's Avatar
Just my 2 cents.
Rob
All the difference in the world. The 2 are no where near comparable.
Old Apr 18, 2012 | 02:46 PM
Ok, then ignore everything I just said then.
Old Apr 18, 2012 | 08:55 PM
Well I just noticed that 275/75/16s dont actually exist, so its down to the other two options. If I lift the front 2" will that allow the 285/75/16s to clear? For people that dont bother to do the math 265/75/16 are 31.8" while 285/75/16s are 32.8" in diameter.
Old Apr 27, 2012 | 12:47 AM
Just to ask again, will 285/75/16s fit with 2" of lift on a 99 2wd?
Old Apr 27, 2012 | 12:03 PM
wandell's Avatar
Yes, 285/75-16's will fit using the OEM wheels or a 16x8 with 4.5 inches of backspacing.
Old Apr 27, 2012 | 11:39 PM
Sweet. I was gonna go with 275/70-17s but if I can fit the 285s on the OEM rim that will be a lot nicer so I dont have to spend as much money at once.
Old Apr 28, 2012 | 02:10 AM
Wait, if the OEM wheels are 16x7, and acording to tire rack the tire can only fit 7.5, how will they fit?
Old Apr 28, 2012 | 08:21 AM
They'll be okay, you'll just need to make sure you monitor air pressure more closely and rotate them properly or you'll get increased wear on them.
Old Apr 28, 2012 | 03:47 PM
Sounds awesome, thanks.
Old Apr 28, 2012 | 05:12 PM
Alex_4.2L's Avatar
With that lift the 285s will fit I'm sure of it because I had them on my 2wd truck. Without the lift they would rub on the front tho
Old Apr 28, 2012 | 11:00 PM
Will I have to worry about rubbing?
Old May 15, 2012 | 01:59 AM
*bump*
Also, can I run 305/70/16s, or will they rub because of the extra width?
Again 99 F150 2wd w/ 1" lift back and 2" front.
