Will they fit question?
Old Mar 24, 2012 | 04:21 PM
dkgreyf150's Avatar
Haven't been around in a while but it's time for new tires so I figured I would go ahead and put new rims and tires. My setup right now is 8 inch lift with 37x13.5r17 Toyo mts. My rims are 17x9 with a -30 offset and I believe a 4.53 backspacing. I want to go with a 37x13.50R22 Toyo mts or trail grapplers but here is where I'm a little confused if they would fit. The rims I want to go with are either fuel hostage 22x11 with a -18 or xd monster in the same size. Any input will be greatly appreciated!
Old Mar 26, 2012 | 01:06 PM
dkgreyf150's Avatar
Come on guys! I know this forum is better than that.
Old Mar 27, 2012 | 12:19 PM
wandell's Avatar
What's the backspacing on the new wheels?
Old Mar 27, 2012 | 02:51 PM
canadianelbow's Avatar
From the spec page http://mhtwheels.com/pdf/specs/D530-...20Hostage1.pdf I dont see a 22X11 with -18.
Could you link to the spec page so we are all on the same page as to which wheels you are talking about, and the specs....
Old Mar 29, 2012 | 09:30 PM
dkgreyf150's Avatar
I figured out they actually don't make that size. I'm still looking for a rim that I like and has the right specs.
Old Mar 29, 2012 | 09:35 PM
dkgreyf150's Avatar
Idk yet! Any recommendations?
Old Mar 30, 2012 | 12:47 PM
wandell's Avatar
I'd stick with a wheel with close your current wheel specs. Like 5 inches of BS and 9 to 10 inches wide. I wouldn't go 11 inches wide.
Old Mar 30, 2012 | 01:14 PM
MossyOak3006's Avatar
If I was you, I would get 20" rims instead of 22". They're cheaper and you can get most rims in any specs you want. There are a lot more choices
Old Mar 30, 2012 | 02:55 PM
dkgreyf150's Avatar
Ok thanks for the help.. I'll probably just end up going with 20x10 as bad as I don't want to
