tire size options
Old Mar 13, 2012 | 02:26 PM
little's Avatar
tire size options
i have a 2007 fx4 screw that came with the 20in rims. i dont like 20s and am going to switch to the 18s in the link below. my qustion is what size tire should i run on these rims with the backspace n offset listed? i dont have a level n i dont plan on but i am going to run an aggresive tire on it. i belive the stock size would have been 275/65/18 could i get away with 285/65/18 with no rubing n no triming? Also what about the pressure monitor? can i get them off my old stock ford rims or will i need new ones? Thanks
http://www.tirerack.com/wheels/Wheel...All&sort=Brand
Old Mar 13, 2012 | 02:48 PM
c1t1d1's Avatar
They should fit fine, yes if you can take them off your rims, not sure but might need to be calibrated or something since dropping in tire size. I believe that should be a 32.6 tire I have the 275/70/18 which is 33 and fit fine.
Old Mar 13, 2012 | 02:51 PM
little's Avatar
yeah kinda hoping i can take them off otherwise there kinda pricy.
Old Mar 13, 2012 | 09:00 PM
j_nuke25's Avatar
They are removable, and if the people label them and put em back in the same position they will not have to be reprogrammed
Old Mar 14, 2012 | 12:51 PM
wandell's Avatar
You could also run 305/60-18's (33x12.50).
Old Mar 15, 2012 | 11:50 AM
little's Avatar
would i have any rubbing?
Old Mar 15, 2012 | 12:21 PM
wandell's Avatar
No.
