another fitment question
315/70/17 with minimal rubbing with a level. Possibly at full turn on uca or lower plastic valance, which is easy to trim. If no level 295/70/17 would be the largest.
Ok thanks for the reply, I have a 2" levelling kit. Looks good then. Was looking at trail grapplers in 295/70/17, was just a little concerned about the rear of wheel well possibly rubbing. Again thanks for the good news.
I disagree. His wheel specs aren't that much different than mine and I fit 315/70/17 easily without issue. Just went off roading a bit this last weekend and not a single rub. I have 8 inch wide with +25 and 5.43 inches bs. His may stick out half inch more than mine and hear the newer 09+ have slightly bigger wheelwells. Doesn't really matter as he sounds set on 295/70/17.
Well surprisingly the 315/70/17 are cheaper than the 295/70/17 in the tires I got. Pawpaw had some 17x9 wheels before the 17x8s on his old 04. He had 315/70/17 bfgs and his 9 inch wide wheels had 5 inches backspacing, which is why they rubbed a little. With yours having 5.71 and the positive offset, I think u would only possibly have to trim the lower plastic valance. Pawpaw help us out.
PawPaw fit 35x12.50's by using an 8 inch wide wheel with 5.5 inches of BS. Deezstx may be able to fit a 35x12.50 using his wheels but he may have to do some trimming. Only way to find out is to test fit one. I think anything smaller than that will fit.
Thanks for all the help guys, I sincerely appreciate it
I will more than likely be looking local. Will surely try the 315's and report back. Will be about a month or so, waiting for tax return to help cover cost. Again thank you guys.
