BFG Rugged Trail TA Mounted Black out?
Old Jan 26, 2012 | 12:29 PM
index1489's Avatar
What I have read has been conflicting, can these tires be mounted with the black letters out?
Old Jan 26, 2012 | 12:35 PM
wandell's Avatar
Not sure. But any tire that requires a certain mounting position will be clearly marked on the tires sidewall.
Old Jan 26, 2012 | 12:38 PM
Pockets's Avatar
Ditto I believe they would be bi directional if there is a choice
Old Jan 26, 2012 | 01:54 PM
Galaxy's Avatar
If it's not clearly marked "directional" or "this side out" or something to that effect, then the answer is yes, you can swap them around. I'd think you'd know, or the web site should make it clear if it's a directional or asymmetric tire. Have you looked?
Old Jan 26, 2012 | 05:19 PM
boyd220's Avatar
You could still mount them black out . Just change sides and it would work.
Old Jan 26, 2012 | 10:45 PM
Galaxy's Avatar
That won't work if theyre asymmetric...only directional.
Old Jan 27, 2012 | 02:14 AM
Galaxy's Avatar
Index...you said Rugged Trail, but I'll assume you meant Rugged Terrain?? BFG doens't have a Rugged Trail on their website, only the Terrain. If so, this tire is neither directional or assymmetric, which means you can certainly mount it either side. All it took was a quck look on the BFG website.
