Will 275/65R20 fit on a stock 2006 FX4
A 2 or 2.5 inch leveling kit will be around $80 for the kit. Do not go over 2.5 inches or the ball joint angles will be too severe to last. If you use the OEM wheels, they may fit at stock height, but they will look worlds better with a leveling kit.
There was a guy on here that was running 275/65s with no leveling kit with stock wheels and said he had no rubbing. Like wandell said, you can get a leveling kit for around $80, and it will look a lot better.
With a 2 inch leveling kit you can easily fit a 285/65-20 (35x11.50) using the stock wheels.
These tires will fit using OEM 20 inch FX4 wheels. Did this on a customer truck at work. Had to trim a tiny bit off his front mudflaps on the inside edge of the flap. Other than that, not one issue.
