tire size pictures please
I picked up an 08 f150 supercrew lariat a couple weeks ago and I'm trying to decide on a wheel and tire setup. I plan to run either a 20x9 or 22x9, most likely the 22. I prefer a wider tire and am pretty sure I will go with a falken stz/04, I had a set before and gor 60k out of them and had no complaints. if I go with the 20 I want to use a 305 55 20. If I go with a 22 I want to use a 305 45 22. I know they will fit I'm just wondering about the look on the truck. If anyone has this size and could post pictures that would be great! Thanks!
Go with the 22's or you will probably wish you would have. Or even 24's with a 305/40/24 . They won't rub and a 40 series is plenty of rubber. Just my opinion. I've run 22's, 24's, and 26's. On my truck . I am currently on my second set of 26's with 305/30/26 kumho tires and ride is good or I wouldn't have went back to the 26's. Wheel wells on these trucks are huge. Hope this helps.
